Zum Hauptinhalt wechseln
HP Pavilion dv2000 Wireless Card Replacement
Was du brauchst
  1. HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: Schritt 1, Bild 1 von 2 HP Pavilion dv2000 Wireless Card Replacement, Wireless Card: Schritt 1, Bild 2 von 2
    • Make sure your computer is powered down and unplugged from the charger before removing any components.
    • Locate and unscrew the single 3.8mm screw holding the wireless card casing in place.
    • Lift up and remove the wireless card casing.
    • The 3.8mm screw will remain in the wireless card casing after you unscrew it.
  2. HP Pavilion dv2000 Wireless Card Replacement: Schritt 2, Bild 1 von 2 HP Pavilion dv2000 Wireless Card Replacement: Schritt 2, Bild 2 von 2
    • Use a pair of tweezers to remove the three antennas from their sockets.
    • Remove the antennas by the contacts connected to the socket, the crimps connecting the wires and the sockets are delicate and are easily damaged.
  3. HP Pavilion dv2000 Wireless Card Replacement: Schritt 3, Bild 1 von 3 HP Pavilion dv2000 Wireless Card Replacement: Schritt 3, Bild 2 von 3 HP Pavilion dv2000 Wireless Card Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Phillips #00 Screwdriver
    $5.49
    Kaufen
    • Remove the two 3.8mm screws holding down the wireless card with your Phillips #00 Screwdriver.
    • Gently pull out your wireless card from its top side to remove it from its holding.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Erik Muniz
820 Reputation
3 Anleitungen geschrieben
CSU Fullerton, Team 2-3, Bruce Fall 2014 Mitglied von CSU Fullerton, Team 2-3, Bruce Fall 2014
CSUF-BRUCE-F14S2G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 14
Letzte 30 Tage: 23
Insgesamt: 2,200
