Zum Hauptinhalt wechseln
Nintendo DSi XL Speakers Replacement
Was du brauchst
  1. Nintendo DSi XL Speakers Replacement, Battery: Schritt 1, Bild 1 von 2 Nintendo DSi XL Speakers Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Speakers Replacement: Schritt 2, Bild 1 von 1
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Speakers Replacement, Rear Bezel: Schritt 3, Bild 1 von 3 Nintendo DSi XL Speakers Replacement, Rear Bezel: Schritt 3, Bild 2 von 3 Nintendo DSi XL Speakers Replacement, Rear Bezel: Schritt 3, Bild 3 von 3
    • Use a push pin to remove the four plastic screw covers on the front bezel.
  4. Nintendo DSi XL Speakers Replacement: Schritt 4, Bild 1 von 1
    • Remove four Phillips screws securing the front bezel to the rear bezel.
  5. Nintendo DSi XL Speakers Replacement: Schritt 5, Bild 1 von 2 Nintendo DSi XL Speakers Replacement: Schritt 5, Bild 2 von 2
    • Using two hands, gently slide the rear bezel upwards.
    • The rear bezel will move only about 2 mm.
  6. Nintendo DSi XL Speakers Replacement: Schritt 6, Bild 1 von 2 Nintendo DSi XL Speakers Replacement: Schritt 6, Bild 2 von 2
    • Insert a spudger into the gap between the front and rear bezel
    • Rotate the spudger away from the DSi XL, prying the two bezels apart.
  7. Nintendo DSi XL Speakers Replacement: Schritt 7, Bild 1 von 1
    • In the same manner as described above, continue prying along the top edge of the front and rear bezels.
  8. Nintendo DSi XL Speakers Replacement: Schritt 8, Bild 1 von 1
    • Separate the rear bezel from the front bezel.
    • Do not attempt to completely remove the rear bezel yet. It is still attached to the front bezel by the rear-facing camera.
  9. Nintendo DSi XL Speakers Replacement: Schritt 9, Bild 1 von 1
    • Use the flat end of a spudger to pry the rear camera off the rear bezel.
    • Remove the rear bezel.
  10. Nintendo DSi XL Speakers Replacement, Speakers: Schritt 10, Bild 1 von 1
    • Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
  11. Nintendo DSi XL Speakers Replacement: Schritt 11, Bild 1 von 1
    • Use a spudger to lift the right speaker from its housing in the front bezel.
  12. Nintendo DSi XL Speakers Replacement: Schritt 12, Bild 1 von 1
    • Use a spudger to lift the left speaker from its housing in the front bezel.
  13. Nintendo DSi XL Speakers Replacement: Schritt 13, Bild 1 von 2 Nintendo DSi XL Speakers Replacement: Schritt 13, Bild 2 von 2
    • De-route the left speaker cable along the top edge of the upper LCD.
  14. Nintendo DSi XL Speakers Replacement: Schritt 14, Bild 1 von 1
    • Open the display slightly, and lift the LCD out of the front bezel.
    • Lay the LCD down next to the DSi XL.
    • Don't attempt to remove the LCD, it is still attached to the front bezel via the display data ribbon cable.
  15. Nintendo DSi XL Speakers Replacement: Schritt 15, Bild 1 von 1
    • Desolder the two solder joints to separate the speakers from the LCD.
    • Right Speaker
    • Left Speaker
    • For both speakers, the red wire (positive lead) is soldered to the left contact. The black wire (negative lead) is soldered to the right contact point.
    • For detailed instructions on how to solder this type of connection, see our guide for repairing soldered connections.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Matthew Newsom
39.524 Reputation
67 Anleitungen geschrieben
3 Kommentare
Thank you for this video but I need some more help cause I dont know if my problem are the speakers or the earphones jack how can I solve this just one clue i need thanks again
Josh - Antwort
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
Dave Horlick - Antwort
is there anyway of adding two more speaker?
vincent johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 41
Insgesamt: 6,785
