Zum Hauptinhalt wechseln
How To Transfer Content To Your New 3DS XL
Was du brauchst
Einführungsvideo
  1. How To Transfer Content To Your New 3DS XL, How To Transfer Content To Your New 3DS XL: Schritt 1, Bild 1 von 1
    • Start by removing the stylus from the frame of the New 3DS XL.
  2. How To Transfer Content To Your New 3DS XL: Schritt 2, Bild 1 von 3 How To Transfer Content To Your New 3DS XL: Schritt 2, Bild 2 von 3 How To Transfer Content To Your New 3DS XL: Schritt 2, Bild 3 von 3
    • Loosen the two captive Phillips #1 screws on the back of the device.
    • These captive screws will conveniently stay in the rear cover, so don't try to remove them.
    • Prying from the thumb slots on each side, pull the rear panel off the back of the device.
  3. How To Transfer Content To Your New 3DS XL: Schritt 3, Bild 1 von 1
    • Press the microSD card slightly deeper into its slot until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • Use a PC to copy the data from the source SD card to the New 3DS XL microSD card.
    • You may need a micro SD to SD adapter.
    • For reassembly, push the microSD card into the slot until it clicks in place.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Geoff Wacker
89.956 Reputation
89 Anleitungen geschrieben
Ein Kommentar
Can anyone who's actually tried the text portion of this guide confirm whether it works? As I understand it, all the data on a 3ds is encrypted with a console-specific key (movable.sed) to prevent exactly this. If it actually worked like this, wouldn't it defeat copy protection almost entirely since any o3ds encrypted ROM could just be copied as-is to a n3ds and run normally?
darth mango - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 74
Insgesamt: 5,742
