Zum Hauptinhalt wechseln
Desktop PC Hard Drive Replacement
Was du brauchst
  1. Desktop PC Hard Drive Replacement, Left Panel: Schritt 1, Bild 1 von 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC Hard Drive Replacement: Schritt 2, Bild 1 von 2 Desktop PC Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC Hard Drive Replacement, Right Panel: Schritt 3, Bild 1 von 1
    • Remove two Phillips #2 head 5mm screws from the back side of the computer case.
  4. Desktop PC Hard Drive Replacement: Schritt 4, Bild 1 von 2 Desktop PC Hard Drive Replacement: Schritt 4, Bild 2 von 2
  5. Desktop PC Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 1
    • Remove two Phillips #2 head 5mm screws holding the hard drive in place.
  6. Desktop PC Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove two Phillips #2 head 5mm screws holding in the other side of the hard drive.
  7. Desktop PC Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Slide the hard drive out from the metal casing.
  8. Desktop PC Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Remove the cables from the back of the hard drive.
Abschluss
59 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 4-5, Maness Spring 2015 Mitglied von Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Mitglieder
45 Anleitungen geschrieben
2 Kommentare
Footnote: the processing of removing a drive from your system may vary slightly depending on the manufacturer of your system, or if you built it yourself; the manufacturer of the case.
Jack G - Antwort
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
Rufin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 127
Insgesamt: 8,783
