Zum Hauptinhalt wechseln
Pebble Steel Battery Replacement
Was du brauchst
  1. Pebble Steel Battery Replacement, Internal Hardware: Schritt 1, Bild 1 von 3 Pebble Steel Battery Replacement, Internal Hardware: Schritt 1, Bild 2 von 3 Pebble Steel Battery Replacement, Internal Hardware: Schritt 1, Bild 3 von 3
    • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
    • Make sure the screws are kept in a safe place to insure they are not lost.
    • Remove the back plate.
  2. Pebble Steel Battery Replacement: Schritt 2, Bild 1 von 2 Pebble Steel Battery Replacement: Schritt 2, Bild 2 von 2
    • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
    • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
    • Adhesive on the back side of the battery holds the internal components to the front case.
    • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
  3. Pebble Steel Battery Replacement, Battery: Schritt 3, Bild 1 von 1
    • Flip the internal components over, and use a plastic opening tool to pry the battery out of the black plastic frame.
    • The battery has a ribbon cable that is soldered to the motherboard. Be sure not to tear the cable when removing the battery from the case.
  4. Pebble Steel Battery Replacement: Schritt 4, Bild 1 von 2 Pebble Steel Battery Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to remove the motherboard from the black plastic frame.
    • The frame has integrated clips above the 4 corners of the motherboard. You can flex the frame gently to release these clips while lifting gently from below.
  5. Pebble Steel Battery Replacement: Schritt 5, Bild 1 von 2 Pebble Steel Battery Replacement: Schritt 5, Bild 2 von 2
    • Turn the battery and motherboard to the opposite side to expose where they are connected.
    • Desolder the two battery connections to remove it from the motherboard.
Abschluss
25 weitere Nutzer:innen haben diese Anleitung absolviert.
MTS
877 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 1-7, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Mitglieder
5 Anleitungen geschrieben
27 Kommentare
And how do you connect the new battery to the motherboard?
What kind of connection is used between the two?
yvesyernaux - Antwort
Instead of desoldering the old battery, I clip the ribbon cable that connects the battery to the motherboard. Trim the ribbon cable as short as possible to the motherboard. The replacement batteries I’ve found have braided wire instead of a ribbon cable, so they can be resoldered to the pads that the remnant of the ribbon cable is attached to. Pebble used enough solder that I’ve never had to add any - just melt the solder that’s already there and drop in the new wires. You can tin the wire ends before attaching them to make a better connection, but you get a good solder connection even with the bare wires. Make sure you get the polarity right - the positive (red) battery wire attaches to the pad closer to the center of the motherboard. If you look carefully there are tiny + and - symbols silkscreened into the motherboard just outboard of the pads.
Rich Stillman -
Farely certain battery ribbon conector is soldered to the circuit board. Gently pulling on it will seperate it but results in tearing. Two other things not mentioned is when removing the rear cover note the round disc object that looks like a button cell, it is glued to the back plate. Care must be taken when removing or one can pull out the red and blue wire from the circuit board. Second thing is a ribbon connector that needs to be disconnected from the cicuit board before the board can be removed. The plastic spudger or tweezers should do he trick. Its easy to miss as a piece of foam hides the connection point.
mjstev17 - Antwort
Anyone found a source for these batteries? I've found the manufacturer but not a retailer.
Paul K - Antwort
There are some really small batteries on aliexpress, do you know the measurements of the original one? I kinda want to replace mine as battery life has been declining.
Sindre Bjerke -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 35
Letzte 30 Tage: 116
Insgesamt: 28,849
