Zum Hauptinhalt wechseln
Canon Selphy CP910 LCD Screen Replacement
Was du brauchst
  1. Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: Schritt 1, Bild 1 von 2 Canon Selphy CP910 LCD Screen Replacement, Disassembling Canon Selphy CP910 Body: Schritt 1, Bild 2 von 2
    • Turn the printer over.
    • Use the PH1 screw bit to remove the three 8 mm screws in the middle of the back plate.
    • Keep track of these screws because you will need them to reassemble the printer.
  2. Canon Selphy CP910 LCD Screen Replacement: Schritt 2, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 2, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Loosen up the four 10 mm corner screws.
    • A screwdriver with a long shaft approximately 7mm in diameter will make it easier to reach these screws.
  3. Canon Selphy CP910 LCD Screen Replacement: Schritt 3, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 3, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Turn the device around and remove the "open" lid.
    • This lid needs to be removed in order to take the printer apart.
    • Gently bend the lid and remove it from its hinges.
  4. Canon Selphy CP910 LCD Screen Replacement: Schritt 4, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 4, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Turn the device back over and lift the top panel up.
    • Disconnect the ribbon cables leading to the LCD screen.
    • Pull the top panel off.
  5. Canon Selphy CP910 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement, LCD Screen: Schritt 5, Bild 3 von 3
    • Once you detach the top, turn the device around.
    • Use the PH0 screw bit to remove the five [size] screws.
  6. Canon Selphy CP910 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Push out the LCD screen from the main case.
    • The screen should slide out freely.
  7. Canon Selphy CP910 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Canon Selphy CP910 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Pull out the rod connecting the LCD screen to the frame.
    • Insert the new screen.
Abschluss
UW Tacoma, Team 1-6, Rose Winter 2016 Mitglied von UW Tacoma, Team 1-6, Rose Winter 2016
UWT-ROSE-W16S1G6
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 20
Insgesamt: 1,184
