Einleitung
It happens to best of us. Your device hits the floor and now the case is damaged. Don't panic, because all you need are a screwdriver and a tool to remove the plastic case and you can replace this component very easily.
Was du brauchst
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Rotate the camera so that the HDMI port is facing up.
Remove the two 5.0 mm JIS #000 screws.
Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
Press the pop-up button highlighted in the picture to release the flash mechanism.
Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
hey, can you show how to remove the lense from this camera, please!!
hey, can you please show how to remove the lens from this camera. thanks
Thank you for your guide, exactly what i was looking for.
Jordan, web dev at Casinos Hunter Fr
Very interesting and useful guide my friend. Really if you could show us how to remove the lenses on this camera model, it would be just super!
Greetings from Oliver Garcia
Content Master and Graphic Quality Control at CasinoLandia
