Zum Hauptinhalt wechseln
Install GNU/Linux on a Legacy System
Englisch
Deutsch
Schritt 2
Kein Bild
Write to USB
  • This step will erase the USB drive you use. Use a new one or make a backup first!
  • There are two methods here which can be used -- pick your preferred method as you see fit, or as the distro you select recommends.
  • Option 1: Go to sourceforge.net and download win32diskimager to make a bootable USB drive. NOTE: This may not work with all Linux distros. If you have issues, try the 2nd option listed.
  • Option 2: Using Rufus, follow this guide to make a bootable USB drive.
  • Select the Linux image you intend to use on the system, and write it to the USB drive following the prompts in the application you choose.
Hier Übersetzung einfügen
