Zum Hauptinhalt wechseln
iMac Intel 21,5" EMC 3068 Displayeinheit austauschen
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 12 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 2
iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 0, Bild 1 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 0, Bild 2 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 0, Bild 3 von 3
  • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
  • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
  • Repeat this step with the other adhesive strip and remove it.
  • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
Falls notwendig, kannst du Reste des Klebebands an der Unterkante mit einer Plastikkarte durchtrennen.
-[* icon_note] If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
+[* icon_caution] Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
+[* black] Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
+[* black] Repeat this step with the other adhesive strip and remove it.
+[* icon_note] If either adhesive strip breaks before it's removed, use a [product|IF145-101|plastic card] to slice through the remaining adhesive.
