Zum Hauptinhalt wechseln
Dell Inspiron Mini 1012 Hard Drive Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Englisch
Deutsch
Schritt 1 übersetzen
Schritt 1
Dell Inspiron Mini 1012 Hard Drive Replacement: Schritt 0, Bild 1 von 2 Dell Inspiron Mini 1012 Hard Drive Replacement: Schritt 0, Bild 2 von 2
  • Turn the device over so that the back (white side) of the device is facing up.
  • Remove battery from laptop by pushing the two tabs outward and pull the battery outward. The tabs are highlighted in blue. Place the battery off to the side.
  • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screw driver with largest phillips head in the box.
  • Make sure to keep the screws separated by step to ensure that they can be put back in the correct location when reversing the steps.
  • Notes about the reversal of steps will appear as a caution mark.
Hier Übersetzung einfügen
