Zum Hauptinhalt wechseln
Removing iPad 3 4G Front Panel
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 153 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 14
Removing iPad 3 4G Front Panel: Schritt 0, Bild 1 von 2 Removing iPad 3 4G Front Panel: Schritt 0, Bild 2 von 2
  • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
  • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
  • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
Hier Übersetzung einfügen
