Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Schritt 5 übersetzen
Schritt 5
Use the point of your spudger to pry up and disconnect the other end of the antenna flex cable from its socket, next to the Lightning Port.
[* black] Use the point of your spudger to pry up and disconnect the other end of the antenna flex cable from its socket, next to the Lightning Port. | |
- | [* icon_reminder] Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press down on the connector with the flat of your spudger until it clicks into place. |
+ | [* icon_reminder] Reconnecting this cable can be tricky. Make it easier by using your [product|IF145-020|tweezers] to hold the flex cable so the connector aligns with its socket. Then, gently press down on the connector with the flat of your spudger until it clicks into place. |
