Zum Hauptinhalt wechseln
Dell Latitude E6410 LCD Screen Replacement
Englisch
Deutsch
Schritt 3
Dell Latitude E6410 LCD Screen Replacement, Remove Bezel: Schritt 0, Bild 1 von 3 Dell Latitude E6410 LCD Screen Replacement, Remove Bezel: Schritt 0, Bild 2 von 3 Dell Latitude E6410 LCD Screen Replacement, Remove Bezel: Schritt 0, Bild 3 von 3
Remove Bezel
  • Use a Spudger to work your way into one of the top areas of the bezel trim surrounding the LCD panel.
  • Work your way around the entire outside rim of the bezel, prying gently to pop the bezel loose from the screen assembly.
  • Some of the clips are tougher to remove than others, be careful not to bend one area of plastic too far. You may have more luck coming from the other side for some clips.
Hier Übersetzung einfügen
