Zum Hauptinhalt wechseln
Base enclosure disassembly
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Base enclosure disassembly, ( If present, remove the mSATA SSD ): Schritt 0, Bild 1 von 3 Base enclosure disassembly, ( If present, remove the mSATA SSD ): Schritt 0, Bild 2 von 3 Base enclosure disassembly, ( If present, remove the mSATA SSD ): Schritt 0, Bild 3 von 3
  • Using a PH#00 screwdriver remove the Phillips PM 2.0x2.5 screw which secures the SSD to the base enclosure: the SSD module will tilt up immediately.
  • Once the module is standing ─ if you're grounded ─ grab it with your fingers as it is shown in pic#3 and slowly pull it out of its connector maintaining its inclination.
  • On top of the previous movement - and always maintaining the SSD tilted - you have to lightly move the module back and forward as the blue arrow shows: think of a pendulum.
Hier Übersetzung einfügen
