Zum Hauptinhalt wechseln
MacBook Pro 13" Touch Bar Late 2016 트랙패드 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 8 übersetzen
Schritt 8
MacBook Pro 13" Touch Bar Late 2016 Trackpad Replacement, Remove the trackpad: Schritt 0, Bild 1 von 3 MacBook Pro 13" Touch Bar Late 2016 Trackpad Replacement, Remove the trackpad: Schritt 0, Bild 2 von 3 MacBook Pro 13" Touch Bar Late 2016 Trackpad Replacement, Remove the trackpad: Schritt 0, Bild 3 von 3
Remove the trackpad
  • Remove the trackpad assembly.
  • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
  • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
트랙패드 어셈블리를 분리하세요.
트랙패드 아랫면에 있는 작은 와셔 여섯 개를 (원형 두 개 및 직사각형 네 개) 잃어버리지 않도록 주의하세요.
[title] Remove the trackpad
[* black] Remove the trackpad assembly.
[* red] Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
+[* icon_reminder] Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
