Zum Hauptinhalt wechseln
iMac G5 20" Model A1145 Front Bezel Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 15 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4
iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 1 von 3 iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 2 von 3 iMac G5 20" Model A1145 Front Bezel Replacement: Schritt 0, Bild 3 von 3
  • Re-orient your iMac so it sits upright on the stand.
  • Insert a plastic card up into the corner of the air vent slot near the top of the rear case.
  • Push the card toward the top of the iMac to release the front bezel latch.
  • Pull the front bezel away from the rear case.
  • Repeat this process for the other side of the front bezel.
  • It may be necessary to apply several layers of duct tape to the top of the access card to aid in releasing the latches.
  • If the bezel refuses to release, try pressing the lower edge back onto the rear case and repeat this opening process.
  • Alternatively, you can use a strong magnet by holding it to the front top left/right corner of the display. You will hear a snapping sound when the hatch is released.
Hier Übersetzung einfügen
