Zum Hauptinhalt wechseln
Canon EOS 20D Rear Case Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 4 übersetzen
Schritt 4
Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: Schritt 0, Bild 1 von 3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: Schritt 0, Bild 2 von 3 Canon EOS 20D Rear Case Replacement, Lift and remove the rear panel: Schritt 0, Bild 3 von 3
  • When lifting the panel, make sure not to lift it too high, since you'll run the risk of tearing the cable, or damaging the connector on the board.
  • Flip the lock on the flex cable connector up with a spudger.
  • The front panel should pop off, now that the cable has been disconnected.
  • When reassembling the device, make sure to insert the left side of the front panel first, since it has a small lip that needs to fit under the left part of the camera case.
Hier Übersetzung einfügen
