Zum Hauptinhalt wechseln
iPhone XS Lower Speaker/하단 스피커 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 4 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 9 übersetzen
Schritt 9
iPhone XS Lower Speaker Replacement: Schritt 0, Bild 1 von 2 iPhone XS Lower Speaker Replacement: Schritt 0, Bild 2 von 2
  • Remove the speaker.
  • The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
  • To help protect against water and dust intrusion, replace the adhesive gasket during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
스피커를 분리하세요.
스피커의 접착 개스킷은 재사용할 수 없습니다. 핀셋으로 남은 접착제를 벗겨주세요.
물과 먼지의 침입을 방지하려면 재조립할 때 접착 개스킷을 교체하여 주세요. 개스킷이 제대로 부착되도록 약간의 isopropyl/이소프로필 알코올과 보풀이 없는 천 또는 커피 필터로 닦아주세요. 스피커에 새 개스킷을 설치한 다음 스피커를 설치하세요.
[* black] Remove the speaker.
[* icon_reminder] The speaker's adhesive gasket is not reusable. Peel away any remaining adhesive residue with tweezers.
-[* icon_reminder] To help protect against water and dust intrusion, [product|IF377-023-1|replace the adhesive gasket|new_window=true] during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
+[* icon_reminder] To help protect against water and dust intrusion, [product|IF406-035|replace the adhesive gasket|new_window=true] during reassembly. Prep the area by cleaning it with a bit of isopropyl alcohol and a lint-free cloth or coffee filter so that the gasket adheres properly. Install a new gasket onto the speaker, and then install the speaker.
