Zum Hauptinhalt wechseln
How to fix broken power button ribbon
Englisch
Deutsch
Schritt 2
How to fix broken power button ribbon, New solder points: Schritt 0, Bild 1 von 1
New solder points
  • Carefully remove your main board from the controller. Its not necessary to disconnect the two large ribbon that goes to the array of sensors. If you do be very careful.
  • Locate the 6 soldering pads at the bottom of the controller near the USB port. Solder a wire to the first pad top left.
  • Locate the 8 solder pads near the bottom left of the main board. Solder a wire to the top right pad.
Hier Übersetzung einfügen
