Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Schritt 2 übersetzen
Schritt 2
Prepare to slice the adhesive
In the following steps, you'll be cutting through the adhesive securing the back cover.
As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas.
The adhesive is the thinnest on the right side of the phone, just below the Bixby button.
[title] Prepare to slice the adhesive |
[* black] In the following steps, you'll be cutting through the adhesive securing the back cover. |
[* icon_note] The adhesive is laid out as seen in the first image, which shows the inside of the cover after it has been removed. |
[* red] As seen from the outside of the phone, you'll be slicing through the adhesive in the highlighted areas. |
[* orange] The adhesive is the thinnest on the right side of the phone, just below the Bixby button. |
