Zum Hauptinhalt wechseln
Dell Latitude E5400 LCD Screen Replacement
Englisch
Koreanisch
Schritt 4
Dell Latitude E5400 LCD Screen Replacement, Removing the screen: Schritt 0, Bild 1 von 3 Dell Latitude E5400 LCD Screen Replacement, Removing the screen: Schritt 0, Bild 2 von 3 Dell Latitude E5400 LCD Screen Replacement, Removing the screen: Schritt 0, Bild 3 von 3
Removing the screen
  • Once you have removed the outer bezel you can start on the LCD panel itself.
  • Now is also a good time to replace the LCD Inverter which is located at the bottom of the LCD. There is a single screw that holds it in place. Then there are two cables that plug into the inverter.
  • To remove the LCD screen, remove the screws from the side of the LCD screen. There should be 4 on each side.
Hier Übersetzung einfügen
