Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen auch die Anleitung, die diese beinhaltet.
Schritt 19 übersetzen
Schritt 19
If the adhesive strips broke and you can no longer access them, insert a plastic card in between the bottom of the battery and the phone's frame.
Carefully push the card down and inward to wedge it underneath the battery and pry it up.
- | [* black] If the adhesive strips broke and you can no longer access them, insert a plastic card in between the bottom of the battery and the phone's frame. |
+ | [* black] If the adhesive strips broke and you can no longer access them, insert a [product|IF145-101|plastic card] in between the bottom of the battery and the phone's frame. |
[* black] Carefully push the card down and inward to wedge it underneath the battery and pry it up. | |
[* icon_caution] Avoid bending the battery while you perform this step. Go slowly and be patient with the remaining adhesive. |
