Zum Hauptinhalt wechseln
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement
Englisch
Deutsch
Schritt 2
Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: Schritt 0, Bild 1 von 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: Schritt 0, Bild 2 von 3 Canon PowerShot SX60 HS Motherboard and Lens Motor Replacement: Schritt 0, Bild 3 von 3
  • Remove one 2mm #00 Philips head screw from the bottom of the camera frame. This will free the lens and motherboard from the frame.
  • Be careful not to completely remove the metal frame, there is still a small wire ribbon attached.
  • Gently separate the metal frame from the lens assembly just enough to reach the wire ribbon on the front side of the camera.
  • Use the rubber tipped tweezers to unplug the wire ribbon.
  • Remove the metal frame and slide the lens motor assembly out of the plastic frame.
Hier Übersetzung einfügen
