Zum Hauptinhalt wechseln
Huawei Mate 30 Pro Teardown
Englisch
Koreanisch
Schritt 15 übersetzen
Schritt 15
Huawei Mate 30 Pro Teardown, Final Thoughts: Schritt 0, Bild 1 von 1
Final Thoughts
  • The Huawei Mate30 Pro earns a 5 out of 10 on our repairability scale (10 is the easiest to repair):
  • Almost every component is modular and can be replaced independently.
  • Only standard Phillips screws are used.
  • Pull tabs make fairly quick work of battery replacement, once you've carved through the rear cover, plastic frame, and some cables.
  • A few components require extended disassembly for service.
  • The display can be removed without removing the battery, although it's still tough to pry off and impeded by some cables.
  • Glued-down front and back glass means greater risk of breakage, while making all repairs more difficult and lengthy.
Hier Übersetzung einfügen
