Zum Hauptinhalt wechseln
Huawei Mate 20 Pro Rear Glass Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 2
Huawei Mate 20 Pro Rear Glass Replacement: Schritt 0, Bild 1 von 3 Huawei Mate 20 Pro Rear Glass Replacement: Schritt 0, Bild 2 von 3 Huawei Mate 20 Pro Rear Glass Replacement: Schritt 0, Bild 3 von 3
  • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
  • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
  • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
  • Insert an opening pick into the gap.
  • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
  • Slide the opening pick to the bottom right corner.
Hier Übersetzung einfügen
