Zum Hauptinhalt wechseln
Upgrade the display panel and replace the display cable
Englisch
Deutsch
Schritt 16
Upgrade the display panel and replace the display cable, Disassemble the display bezel (2 of 2): Schritt 0, Bild 1 von 3 Upgrade the display panel and replace the display cable, Disassemble the display bezel (2 of 2): Schritt 0, Bild 2 von 3 Upgrade the display panel and replace the display cable, Disassemble the display bezel (2 of 2): Schritt 0, Bild 3 von 3
  • There is a thick adhesive stripe that attaches the bottom edge of the bezel to the display panel. Therefore, keeping the bezel tilted up a bit with one hand, detach the tape from the bezel using the other hand trying to leave the adhesive attached to the display. Start from a corner and go slowly along the edge.
  • If you will be not disposing the old screen, wear the anti-static wristband before beginning the separation and while you are taking the bezel away, try not to detach the dove-grey shield that covers the LED driver of the display (in other words, do not obtain something like the bottom of pic#3).
Hier Übersetzung einfügen
