Zum Hauptinhalt wechseln
Upgrade the display panel and replace the display cable
Englisch
Deutsch
Schritt 22
Upgrade the display panel and replace the display cable, Connect the new display cable to the new display: Schritt 0, Bild 1 von 3 Upgrade the display panel and replace the display cable, Connect the new display cable to the new display: Schritt 0, Bild 2 von 3 Upgrade the display panel and replace the display cable, Connect the new display cable to the new display: Schritt 0, Bild 3 von 3
  • Lay the new display panel over its packaging ─ or any other soft layer you have at hand ─ with its front side facing the table so that you have the display connector in front of you, as in pic#1.
  • Grab the end of the new cable with your fingers as you did with the old one, align it and push it inside the connector straightly and powerfully.
  • With high probability the connector will softly move backwards a little while you are pushing the cable inside: it's ok, keep pushing it forcefully in order to connect them right. The connector will automatically come back when you stop pushing.
  • STOP only when you see a flat full golden surface between the two parts. Do not stop pushing when there are still black empty spaces as it is shown in pic#3, that is not enough. When I later switched on the laptop, the display was not working good and I had to disassemble the bezel and the panel again to push the cable further inside.
Hier Übersetzung einfügen
