Zum Hauptinhalt wechseln
후면 커버 분리
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 14 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 7
Back Cover Removal: Schritt 0, Bild 1 von 3 Back Cover Removal: Schritt 0, Bild 2 von 3 Back Cover Removal: Schritt 0, Bild 3 von 3
  • Be careful near the corners, as the glass is weakest there.
  • Insert an opening pick into the lower-left corner of the rear panel.
  • Using another opening pick, cut the adhesive along the left edge of the rear panel.
  • Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
  • It is fine if opening picks fall out as the back cover becomes separated.
후면 패널 왼편-하단 모서리에 여는 픽을 끼우세요.
다른 여는 픽을 사용하여 후면 패널의 왼편 가장자리를 따라 접착제를 자르세요.
지문 센서 근처 왼편 가장자리에 픽을 절반 이상 끼우지 마세요. 아니면 내부 리본 케이블을 손상할 수 있습니다.
후면 커버가 분리될 때 여는 픽은 빠져도 괜찮습니다.
+[* icon_caution] Be careful near the corners, as the glass is weakest there.
[* black] Insert an opening pick into the lower-left corner of the rear panel.
[* black] Using another opening pick, cut the adhesive along the left edge of the rear panel.
-[* icon_caution] Do not insert an opening pick in more than half way on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
+[* icon_caution] Don't insert an opening pick in more than halfway on the left edge near the fingerprint sensor or you may damage the ribbon cable inside.
[* icon_note] It is fine if opening picks fall out as the back cover becomes separated.
