Zum Hauptinhalt wechseln
Samsung Galaxy Note9 배터리 교체
Englisch
Koreanisch
Schritt 2 übersetzen
Schritt 2
Samsung Galaxy Note9 Battery Replacement: Schritt 0, Bild 1 von 3 Samsung Galaxy Note9 Battery Replacement: Schritt 0, Bild 2 von 3 Samsung Galaxy Note9 Battery Replacement: Schritt 0, Bild 3 von 3
  • Do not bend the battery. Do not reuse the battery.
  • Apply a suction cup to the battery.
  • It may take multiple attempts to get the suction cup to adhere. Apply is as close to the center of the battery as possible and avoid the white sticker at the bottom of the battery.
  • Use firm, steady force to lift the battery straight up until there is a gap large enough to insert the opening pick.
  • Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
  • If the battery won’t pry out easily, apply a little more alcohol and repeat the last step to further weaken the adhesive.
  • Remove the battery.
  • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
배터리에 흡입 컵을 붙이세요.
흡입 컵을 붙이려면 여러 번 시도해야 할 수 있습니다. 가능한 한 배터리 중앙에 가깝게 대고 배터리 하단 흰색 스티커는 피하세요.
여는 픽을 끼울 수 있을 정도의 간격이 생길 때까지 배터리를 똑바로 들어 올리세요.
배터리 하단 가장자리 아랫면에 여는 픽을 끼우고 비틀어서 배터리 접착제를 풀어주세요.
배터리가 쉽게 빠지지 않으면, 알코올을 조금 더 바르고 마지막 단계를 반복하여 접착제를 더 약하게 만드세요.
배터리를 분리하세요.
배터리를 구부리지 마세요. 배터리를 재사용하지 마세요.
+[* icon_caution] Do not bend the battery. Do not reuse the battery.
[* black] Apply a suction cup to the battery.
[* icon_note] It may take multiple attempts to get the suction cup to adhere. Apply is as close to the center of the battery as possible and avoid the white sticker at the bottom of the battery.
-[* black] Lift the battery straight up until there is a gap large enough to insert the opening pick.
+[* black] Use firm, steady force to lift the battery straight up until there is a gap large enough to insert the opening pick.
[* black] Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
[* icon_note] If the battery won’t pry out easily, apply a little more alcohol and repeat the last step to further weaken the adhesive.
[* black] Remove the battery.
-[* icon_caution] Do not bend the battery. Do not reuse the battery.
+[* black] If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
