Zum Hauptinhalt wechseln
Fitbit Sense Teardown
Englisch
Deutsch
Schritt 6
Fitbit Sense Teardown: Schritt 0, Bild 1 von 3 Fitbit Sense Teardown: Schritt 0, Bild 2 von 3 Fitbit Sense Teardown: Schritt 0, Bild 3 von 3
  • Two more brackets tucked up against the sides of the housing keep a few more key components in place: loudspeaker and pressure sensor on one side, and a microphone, vibration motor, and psuedo-button on the other.
  • Minus the vibration motor, all of these components connect to the sensor board at the bottom of the housing and terminate in soldered connections.
  • Even if you're handy with a soldering iron though, that sensor board lives under a metal plate and the whole affair is locked in with some serious permanent adhesive. It's unlikely you'll be able to remove it without damaging something.
  • The edge around the display features two separated metal brackets for reading your EDA levels (electrodermal activity) and taking that ECG.
Hier Übersetzung einfügen
