Zum Hauptinhalt wechseln
DJI Mavic Pro Front Arm Assembly Replacement
Englisch
Deutsch
Schritt 12
DJI Mavic Pro Front Arm Assembly Replacement: Schritt 0, Bild 1 von 2 DJI Mavic Pro Front Arm Assembly Replacement: Schritt 0, Bild 2 von 2
  • Use a metal pry tool or flat head screwdriver to lift out the spring-loaded hinge
  • The spring in this hinge makes it difficult to reseat during reassembly. The easiest way I found to replace it was to fold the arm back into the closed position, and then grab across the top of the hinge with the very tip of a pair of needle nose pliers, using the pliers to rotate the hinge into position and press it down into place.
Hier Übersetzung einfügen
