Zum Hauptinhalt wechseln
Polar Wind 8" High Velocity Fan Blades Replacement
Englisch
Koreanisch
Schritt 5
Polar Wind 8" High Velocity Fan Blades Replacement: Schritt 0, Bild 1 von 3 Polar Wind 8" High Velocity Fan Blades Replacement: Schritt 0, Bild 2 von 3 Polar Wind 8" High Velocity Fan Blades Replacement: Schritt 0, Bild 3 von 3
  • Firmly grasp the base of the blades, pushing it down and turning clockwise to slide down to the base of the rod.
  • Use a pair of pliers to remove the center disk by pinching the rim and pulling upwards.
  • Once it is loosened, squeeze the bottom of the disk and the tip of the rod between your pliers to more easily remove the disk.
  • The disk may be difficult to remove. Using lube may help slide it off more easily, but it is not required.
Hier Übersetzung einfügen
