Zum Hauptinhalt wechseln
Motherboard entfernen
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese beinhalten.
Schritt 10 übersetzen
Englisch
Deutsch
Schritt 10
Motherboard Removal, Lift out the motherboard: Schritt 0, Bild 1 von 3 Motherboard Removal, Lift out the motherboard: Schritt 0, Bild 2 von 3 Motherboard Removal, Lift out the motherboard: Schritt 0, Bild 3 von 3
  • Carefully guide the joysticks through the front case and lift the motherboard out.
  • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
  • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
Führe die Joysticks vorsichtig durch die Gehäusevorderseite und hebe das Motherboard heraus.
Entferne das Motherboard noch nicht vollständig. Vier angelötete Kabel verbinden das Motherboard mit den Vibrationsmotoren.
[title] Lift out the motherboard
[* black] Carefully guide the joysticks through the front case and lift the motherboard out.
+[* black] The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
[* icon_caution] ***Do not completely remove the motherboard.*** There are four soldered wires tethering the motherboard to the vibrator motors.
