Zum Hauptinhalt wechseln
Sony DualSense Controller Gehäuseunterteil ersetzen
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 26 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 4
Rear Case Separation: Schritt 0, Bild 1 von 3 Rear Case Separation: Schritt 0, Bild 2 von 3 Rear Case Separation: Schritt 0, Bild 3 von 3
  • Tight plastic clips secure the left and right edges of the rear case.
  • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
  • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
Hier Übersetzung einfügen
-[title] Release the rear case clips
-[* icon_note] Tight plastic clips secure the left and right edges of the rear case.
+[* icon_note] Tight plastic clips secure the [link|https://guide-images.cdn.ifixit.com/igi/cSFE5AIPQAOqYn5A.full|left|new_window=true] and [link|https://guide-images.cdn.ifixit.com/igi/gssrnZ6hIcnAIKxY.full|right|new_window=true] edges of the rear case.
[* black] Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
-[* black] Slide the spudger along the left edge and gently pry the shells apart to separate the clips.
+[* black] Slide the spudger along the left edge and gently pry the shells apart to release the clips.
