Zum Hauptinhalt wechseln
MacBook Unibody Model A1278 Front Display Glass Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Deutsch
Schritt 6
MacBook Unibody Model A1278 Front Display Glass Replacement: Schritt 0, Bild 1 von 2 MacBook Unibody Model A1278 Front Display Glass Replacement: Schritt 0, Bild 2 von 2
  • Use a heat gun to soften the adhesive under the black strip near the upper left corner of the glass display panel.
  • Attach a suction cup near the upper left corner of the glass display panel.
  • Pull up on the suction cup and use the flat end of a spudger to carefully pry the glass display panel out of the display assembly.
  • Once the upper left corner has been separated from the display, it may be helpful to use a guitar pick or another thin plastic object to keep the glass from sticking back down to the display assembly.
Hier Übersetzung einfügen
