Zum Hauptinhalt wechseln
MacBook Pro 13" Two Thunderbolt Ports Late 2020 하단 케이스 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 10 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 6
MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: Schritt 0, Bild 1 von 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: Schritt 0, Bild 2 von 3 MacBook Pro 13" Two Thunderbolt Ports Late 2020 Lower Case Replacement: Schritt 0, Bild 3 von 3
  • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
  • It may help to pull first at one corner, then the other.
  • Pull to the side—not up.
  • This may require a lot of force.
  • The edges of the case can be sharp, so grip the sides carefully.
하단 케이스를 MacBook 전면을 향해 단단히 당겨 (힌지 부분에서 멀리) 하단 케이스를 고정하는 마지막 클립을 풀어주세요.
한쪽 모서리를 먼저 당기고 나서 다른 모서리를 당기면 도움이 됩니다.
옆으로 당기세요—위로 말고.
이 작업은 많은 힘이 필요할 수 있습니다.
[* black] Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
[* icon_note] It may help to pull first at one corner, then the other.
[* icon_caution] Pull to the side—not up.
[* icon_caution] This may require a lot of force.
+ [* icon_caution] The edges of the case can be sharp, so grip the sides carefully.
