Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese beinhalten.
Schritt 19 übersetzen
Schritt 19
Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
Repeat this procedure at different points around the shield until it is free. Remove the shield.
- | [* black] Insert one point of a pair of |
+ | [* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the edge of the EMI shield covering the digitizer connector. |
[* black] Use the tweezers to pry the EMI shield away from the display as much as you can without bending it. | |
[* black] Repeat this procedure at different points around the shield until it is free. Remove the shield. | |
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly. |
