Zum Hauptinhalt wechseln
Microsoft Surface Pro 6 방열판교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Microsoft Surface Pro 6 Heat Sink Replacement, Remove the heat sink shield: Schritt 0, Bild 1 von 2 Microsoft Surface Pro 6 Heat Sink Replacement, Remove the heat sink shield: Schritt 0, Bild 2 von 2
  • Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
  • Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
  • Try not to deform the shield too much—you will need to reinstall it during reassembly.
  • Take care not to puncture the battery with the tweezers while working on this shield.
핀셋의 한 뾰족한 부분을 방열판을 덮고 있는 EMI 실드 모서리의 틈에 끼우세요.
핀셋을 사용하여 EMI 실드를 구부리지 않으며 마더보드에서 최대한 멀찍이 EMI 실드를 들어 올리세요. 아직 분리하지 마세요.
실드를 너무 많이 변형하지 마세요—재조립할 때 실드를 다시 설치해야 합니다.
이 실드에 작업하는 동안 핀셋으로 배터리에 구멍을 내지 않도록 주의하세요.
[title] Remove the heat sink shield
-[* black] Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
+[* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the corner of the EMI shield covering the heat sink.
[* black] Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly.
[* icon_caution] Take care not to puncture the battery with the tweezers while working on this shield.
