Zum Hauptinhalt wechseln
Microsoft Surface Laptop 3 15" SSD 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 19 Anleitungen, die diese beinhalten.
Schritt 2 übersetzen
Englisch
Koreanisch
Schritt 2
Microsoft Surface Laptop 3 15" SSD Replacement, Remove the SSD: Schritt 0, Bild 1 von 2 Microsoft Surface Laptop 3 15" SSD Replacement, Remove the SSD: Schritt 0, Bild 2 von 2
Remove the SSD
  • With the SSD screw removed, the SSD will pop up at a shallow angle.
  • Grip the end of the SSD and pull it away from its board connector to remove it.
  • During reassembly, insert the SSD at a shallow angle into its board connector, and secure it back into its horizontal position with the SSD screw.
SSD 나사를 풀어주면 SSD가 낮은 각도로 올라옵니다.
SSD의 끝을 잡고 보드 커넥터에서 당겨서 분리하세요.
재조립할 때, SSD를 보드 커넥터에 낮은 각도로 끼우고 SSD 나사를 사용하여 수평으로 다시 고정하세요.
