Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 9 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 1 übersetzen
Schritt 1
Remove the heat sink shield
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet.
[title] Remove the heat sink shield | |
- | [* black] Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the heat sink. |
+ | [* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the corner of the EMI shield covering the heat sink. |
[* black] Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. Do not remove it yet. | |
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly. | |
[* icon_caution] Take care not to puncture the battery with the tweezers while working on this shield. |
