Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Schritt 6 übersetzen
Schritt 6
Remove the camera connector shield
Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors.
Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it.
Repeat this procedure at different points around the shield until it is free. Remove the shield.
[title] Remove the camera connector shield | |
- | [* black] Insert one point of a pair of pointed tweezers into a gap in the corner of the EMI shield covering the camera connectors. |
+ | [* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the corner of the EMI shield covering the camera connectors. |
[* black] Use the tweezers to pry the EMI shield away from the motherboard as much as you can without bending it. | |
[* black] Repeat this procedure at different points around the shield until it is free. Remove the shield. | |
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly. |
