Zum Hauptinhalt wechseln
How to Fix the C6 Error for a Pressure Cooker
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
How to Fix the C6 Error for a Pressure Cooker, Access the pressure cooker innards: Schritt 0, Bild 1 von 3 How to Fix the C6 Error for a Pressure Cooker, Access the pressure cooker innards: Schritt 0, Bild 2 von 3 How to Fix the C6 Error for a Pressure Cooker, Access the pressure cooker innards: Schritt 0, Bild 3 von 3
  • Be sure to unplug your pressure cooker before you begin your repair. Once opened, there's exposed wiring that can electrocute you if the device is plugged in.
  • Flip the pressure cooker upside down.
  • Use a T15 Torx driver to remove the screw securing the bottom plate.
  • Twist and remove the bottom plate.
  • Depending on your model, this procedure may be slightly different.
Hier Übersetzung einfügen
