Zum Hauptinhalt wechseln
How to Fix the C6 Error for a Pressure Cooker
Englisch
Koreanisch
Schritt 4
How to Fix the C6 Error for a Pressure Cooker, Diagnose the C6 or C6H error: Schritt 0, Bild 1 von 2 How to Fix the C6 Error for a Pressure Cooker, Diagnose the C6 or C6H error: Schritt 0, Bild 2 von 2
  • The next three steps show how to test the high pressure sensor more extensively. You should check this sensor if you get a C6 or C6H error.
  • If you don't have a "duo" pressure cooker, you will only have one pressure sensor, and it's this high pressure one.
  • Make sure the pressure cooker is unplugged from the outlet.
  • Use pliers or your fingers to lift and disconnect one of the sensor's spade connectors from the circuit board.
  • These connectors can be stubborn. Gently wiggle the connector as you pull to loosen it.
  • This disconnects the sensor electrically, so we can do a continuity test.
Hier Übersetzung einfügen
