Zum Hauptinhalt wechseln
How to Fix the C6 Error for a Pressure Cooker
Englisch
Koreanisch
Schritt 12 übersetzen
Schritt 12
How to Fix the C6 Error for a Pressure Cooker: Schritt 0, Bild 1 von 3 How to Fix the C6 Error for a Pressure Cooker: Schritt 0, Bild 2 von 3 How to Fix the C6 Error for a Pressure Cooker: Schritt 0, Bild 3 von 3
  • If your new high pressure sensor is under-pressurizing or over-pressurizing, follow this step to adjust the pressure sensor.
  • Unplug your pressure cooker and disassemble it until you can access the pressure sensors.
  • Use a spudger to pry away the white adhesive covering the high pressure sensor calibration screw.
  • This reveals the calibration screw's flat screwhead.
  • If your pressure cooker is over-pressurizing, use a screwdriver to turn the screw clockwise (tighten) by a quarter turn. This makes the sensor trigger and turn off at a lower heat.
  • If your pressure cooker is under-pressurizing, use a screwdriver to turn the screw counter-clockwise (loosen) by a quarter turn. This makes the sensor trigger and turn off at a higher heat.
  • Reassemble the pressure cooker and perform the pressure test in the previous step. Readjust the calibration screw as needed.
  • Once you've calibrated the pressure cooker, cover the calibration screw with some silicone or heat-tolerant adhesive. This prevents the calibration screw from turning.
Hier Übersetzung einfügen
