Zum Hauptinhalt wechseln
여는 절차
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 73 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 13
Opening Procedure: Schritt 0, Bild 1 von 3 Opening Procedure: Schritt 0, Bild 2 von 3 Opening Procedure: Schritt 0, Bild 3 von 3
  • Pull the pick out until only the tip is between the digitizer and the frame.
  • Slide the pick above the front camera to separate the adhesive.
  • Leave the pick near the right side of the front camera before continuing.
디지타이저와 프레임 사이에 끝 부분만 들어갈 때까지 픽을 당겨 빼내세요.
픽을 전면 카메라 위로 밀어서 접착제를 분리하세요.
계속하기 전에 픽을 전면 카메라의 오른쪽 근처에 두세요.
