Zum Hauptinhalt wechseln
Samsung Galaxy S22 Ultra 레이저 AF 및 마더보드 커버 교체
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 3 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 3 übersetzen
Schritt 3
Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: Schritt 0, Bild 1 von 3 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: Schritt 0, Bild 2 von 3 Samsung Galaxy S22 Ultra Laser AF and Motherboard Cover Replacement, Remove the motherboard cover and laser AF module: Schritt 0, Bild 3 von 3
  • Insert the pointed end of your spudger between the bottom right corner of the motherboard cover and the frame.
  • Pry up on the cover to unclip it from the frame.
  • Remove the motherboard cover and laser AF module.
  • During reassembly, press down on the cover to secure its clips to the frame.
Spudger/스퍼저의 뾰족한 끝을 마더보드 커버 하단 오른편 모서리와 프레임 사이에 끼우세요.
커버를 들어 올려 프레임에서 클립을 풀어주세요.
마더보드 커버와 레이저 AF 모듈을 분리하세요.
재조립할 때 커버를 눌러서 클립을 프레임에 고정하세요.
