Zum Hauptinhalt wechseln
Garmin Avionics Wiring Termination
Englisch
Deutsch
Schritt 7
Garmin Avionics Wiring Termination, Shielding termination: Schritt 0, Bild 1 von 2 Garmin Avionics Wiring Termination, Shielding termination: Schritt 0, Bild 2 von 2
  • Insert the environmental splice over the cut shielding block and insert the shield braid into it. The solder ring must go over both the exposed shield and the braid.
  • Insert a piece of heat shrink over the end of the wire where the shield and outer insulation is cut. This will protect the end of the wire
  • Heat the splice and heat-shrink with a heat gun. Ensure the solder flows in the splice soldering the braid to the shield.
Hier Übersetzung einfügen
