Zum Hauptinhalt wechseln
Airplane Life Vest Autofill Regulator Teardown
Englisch
Deutsch
Schritt 6
Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: Schritt 0, Bild 1 von 3 Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: Schritt 0, Bild 2 von 3 Airplane Life Vest Autofill Regulator Teardown, Piercing Pin: Schritt 0, Bild 3 von 3
Piercing Pin
  • The piercing pin is installed going through the entire body of the inflator.
  • With a scribe it can be removed. There are 3 pieces: the pin, a spring (causing the pin to return after use), and an O-ring to only allow the air one path into the airbag.
  • With the pin removed a path is visible from where the CO2 bottle mounts to the lever.
Hier Übersetzung einfügen
