Zum Hauptinhalt wechseln
Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement
Englisch
Koreanisch
Schritt 4
Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: Schritt 0, Bild 1 von 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: Schritt 0, Bild 2 von 3 Fulminare H13 True HEPA Air Purifier Ionizer Wires Replacement: Schritt 0, Bild 3 von 3
  • Next, you will see a fan. Locate the four screws that hold the fan together as shown on the left. The screws are 3.2 mm in size.
  • Use the same screwdriver as before-Phillips-head screwdriver- and unscrew all the screws, and then place them in a secure area. Make sure not to get them mixed up with the other screws!
  • Lastly, we are going to detach the fan. Once the screws are removed, gently lift the fan from its place. Along with that, if clips are holding the fan, undo them before pulling the fan out.
Hier Übersetzung einfügen
