Zum Hauptinhalt wechseln
HP Chromebook 11 G5 EE Teardown/Disassembly
Englisch
Deutsch
Schritt 15 übersetzen
Schritt 15
HP Chromebook 11 G5 EE Teardown/Disassembly: Schritt 0, Bild 1 von 2 HP Chromebook 11 G5 EE Teardown/Disassembly: Schritt 0, Bild 2 von 2
  • The motherboard is the next component to be removed.
  • First, disconnect the barrel plug from the motherboard.
  • Next, remove the 4 PH1 screws that secure the motherboard to the enclosure
  • Finally, remove the single PH1 screw securing the barrel plug to the enclosure, and remove the motherboard.
  • The barrel plug cable can then be pulled out with the barrel plug by simply lifting it off the enclosure, as it uses very little adhesive
Hier Übersetzung einfügen
